Does Aperture have the "treat leading zeros as alphanumeric" option that Pandora had
One a a global setting that instructed Pandora to treat any input field with leading zeros as alphanumeric so that the leading zeros were preserved. While I can see that one can set a field which has can have leading zeros as alphanumeric, this seems to require an analysis of the data to know that it has leading zeros - one knows about bank sort codes, bank account numbers, telephone numbers but there are often others lurking and an the global function was most useful.
There is no global setting for treating any column of data with a leading 0 as alphanumeric, you can set a file loaded to treat every column as alphanumeric on load. This avoids losing leading zeros if they're significant.
You will have to convert dates to a date type before using and date comparison functions however. This can be done within a transformation if required.
Thanks, it was as I expected. A pity, that was a useful feature in Pandora!
