How to highlight null/empty values
Sueann See
Experian Super Contributor
When performing exploratory data analysis, or presenting data in grids in a dashboard, you may want to highlight null/empty values. Within Aperture, you can build a custom function to do this and apply it to one or more columns in your dataset. Here is an example:
- Go To Functions, Create new function.
- Create a parameter for the column value and optionally specify a test dataset and column value to be used for testing.
- Drag the following functions onto the canvas:
- The Is then else function in order to apply the "highlight" when there is null or empty value detected.
- The Warning message function, in order to achieve the "highlight" effect.
- The Is Null function, where you can include 2 checks, Is Null or Is Empty.
- Assuming you want to create a View with all the null/empty values highlighted, go to Datasets, click on a Dataset name, Explore, Transform.
- At the Transformation screen, select all the columns in the dataset, select Existing column, select your custom function.
- When you click Apply transformation, this will apply your custom function on all the existing columns in the dataset, highlighting all the null/empty values. You can then save this as a View.
- The View can be applied to a dashboard.
3
Thanks for sharing @Sueann See I didn't know you could do that :)
