Not been able to drill down from a view created from profile data step
Thanks, I'll keep an eye for the 2.7 version.
Hi Marco
This might depend which version you are using as there have been improvements to Interactivity recently which will be promoted in version 2.7
Which version are you using? and are you using the View in a different Space or as a Dashboard widget or something else?
Hi Josh,
Thanks for the reply.
Version 2.6.7.31.
The view is been used on the same space and the intention was to have it as a Dashboard widget
You mentioned that the View is already set to 'Interactive' which is correct and you can read more about here: https://community.experianaperture.io/discussion/789/aperture-data-studio-2-6-3
The good news is you have set everything up correctly. The published view as a dashboard widget would be interactive right now if you were using the Validate workflow step results. However, for Profile (and Group) results you will need to upgrade to version 2.7 once it is available in the coming weeks and it will automatically/magically make your Profile widget interactive without you having to make any changes
- 471 Get involved
- 13 Support
- 269 Resources
- 218 Community categories
