Group step in Workflow throws java.lang.IllegalArgumentException: Invalid handle
Hello there,
I have a workflow in Experian's Aperture Data Studio (version 2.5.11.115) which unions 24 inputs
From this union, I then have a group step which allows me to see what the validation results are for each category
When I use aggregates, there is no problem but when I group and aggregate together, I get this error thrown:
The unusual aspect is that I have pretty much a mirror copy of this workflow which is working fine and when I run the combined workflow job, the output is produced without issues.
If there is someone who can help me diagnose this issue, that would be much appreciated
Best thing to do here is to raise a case with your local support team, who will be able to assist: https://docs.experianaperture.io/more/contact-support
For them to be able to investigate, they'll likely need:
- The full log files (%DATABASE_ROOT%/data/log) from the day you experienced the issue
- If possible, an export of the workflow and its dependencies (datasets - schemas only, not data -, functions, embedded workflows...)
In my experience, "Invalid handle" errors originate from the Validate Addresses step, do you have that as part of the workflow?
- 485 Get involved
