Setup Secure SSL using self-signed certificates
2»
  • @Henry Simms ,
    can you remove our server IP from comment above, didn't know I was allowed to share it on public forum.
    thank you .
  • @Henry Simms left the path blank, comes back with error , .... not licensed.
    where do we usually find the already licensed key,
    as I belive it can be executed through swagger ui also for the find duplicates.
    Thanks @HussainSyed our team will contact you directly with the remote Find Dupes license key.
    @Josh Boxer FYI
  • @Sueann See How do I apply the
    Use Data Studio to apply your Find duplicates step license: click on your username, select the Update license dialog and enter your license key.
    when I already have the licensed product but it is showing as not licensed.
  • @Josh Boxer
    can you please assist as it is affecting business.
    @Sueann See
    Yes I have read it in the instructions, but have less idea about where the LK is ..
    @Henry Simms thanks
  • @Henry Simms
    I have sent the email according to instructions you gave.
    thanks.
