Join after a filter
Hello,
In Aperture 2.2.6.118 , when we use a join function just after a filter , we get error message whern we clic on show step result of the Join step: Index: 2, Size:2.
When we remove the filter it works very well.
Thank you in advance.
Best regards
We would need more information to help diagnose the issue here. There are two places you can look
a) The Workflow Operations API may contain a more detailed error message: http://<server>/api/docs/index.html#/Workflow%20Execution%20Operations/jobDetail
b) Else you will need to access the verbose logs (to see the error and stack trace):
C:\ApertureDataStudio\data\log\YYYY-MM\datastudio-DD-MM-YYYY-1.log
Once you have additional detail, if you need further support then I would suggest raising a case https://docs.experianaperture.io/more/contact-support/ (for you it would be with UK team). Note than as well as the log file (or specific part of log) they may ask you to share your workflow by exporting it as a .dmx file https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/monitor-data-and-troubleshoot/migrate-metadata/#exportfromaspace
Want to add that behaviour does not happen all time, but in specific wf.
I don't know why
Best regards
To clarify, your workflow contains a Filter step followed by a Join step. Clicking Show step results on the Join step returns an error message. What is the error message?
If you remove the Filter step it works correctly and a similar Filter to Join set up in other workflows works correctly.
Thank you Josh for your reactivity
You are right
The message says: Index: 2, Size:2
I have seen this issu only with this specific wf, because I create a simple wf with a very small data set (filter + join) , and it work
- 471 Get involved
- 13 Support
- 269 Resources
- 218 Community categories
