4009: Exception occurred
Itumeleng_sage
Member
When filtering on a field I get an error 4009: Exception occurred
When you add a field to your SQL table and update the dataset works fine, but I had to recreate the view linked to the dataset
@Itumeleng_sage have you logged a ticket with our support desk?
@Sueann See I re-created the view and its working fine now
@Itumeleng_sage it would be useful to know if you see this often and the circumstances under which this occurs so that @Ian Hayden can investigate further.
@Clinton Jones I only encounter this once after adding a field on SQL source table, then updated/refresh Aperture dataset and the linked view was updated but there where issues with that new field in the view i.e. values not correct and filter showing that error.
- 484 Get involved
- 18 Support
- 253 Resources
