Recommended Approach for Using Experian Email and Phone Validation Results
Purpose
This article provides a recommended approach for interpreting Experian Email and Phone Validation results and converting them into practical downstream actions. The goal is to help teams decide whether a contact point should be accepted, rejected, corrected, retested, or manually reviewed.
Experian’s validation outputs should not be treated as a single universal pass/fail outcome. The correct action depends on the validation result, the confidence level, the communication channel, and the business context. For example, a result that may be acceptable for a low-risk marketing campaign may be unsuitable for healthcare, financial, identity, or safety-critical communications.
The source material confirms that email validation is performed first at syntax level and then through real-time mailbox-level validation. The output includes validation result, verbose result, and, where available, a suggested correction. It also notes that suggested corrections should be used at the client’s discretion because they may not always be the correct email to use going forward. The confidence-level guidance also states that email and phone validation responses are real-time checks and can change depending on the email provider, mailbox state, phone network, or telco response at the time of query.
Recommended Output Columns
The validation file should retain the original Experian outputs and add recommendation fields for business use. The recommendation should be appended, not used to overwrite the raw validation result.
Column | Purpose |
| Original Experian email result, such as Verified, Undeliverable, Unknown, Disposable, or Illegitimate. |
| More detailed reason, such as mailboxFull, acceptAll, syntaxFailure, roleAccount, timeout, or typoDomain. |
| Suggested email correction, where Experian provides one. |
| New derived column indicating the recommended action. |
| Phone type, such as Mobile, Landline, VoIP, Toll free, Premium, or Unknown. |
| Phone validation confidence or status, such as Live, Dead, Absent Subscriber, No Coverage, or Inconclusive. |
| Derived action for phone use. |
| Overall preferred contact action across available channels. |
| Plain-English reason for the recommendation. |
| Indicates whether the recommendation was based on Healthcare, Marketing, Financial Services, Government, Retail, or another policy profile. |
Recommended Email Recommendation Column
The following table extends the same concept used in the phone recommendation guidance by adding a recommended action for email results.
Email Validation Result | Verbose Result Examples | Baseline Recommendation | Suggested Handling |
Verified | verified | Accept | Use the email address for normal communications, subject to consent and business rules. |
Undeliverable | mailboxDoesNotExist, mailboxDisabled, syntaxFailure | Reject | Suppress from email use. Request an updated email address through another channel. |
Undeliverable | mailboxFull | Retest / Conditional Accept | Treat as potentially temporary. Retest before rejecting permanently, especially for non-critical communications. |
Unreachable | unreachable | Retest / Review | Do not rely on the email for critical communications. Retest later or use an alternate channel. |
Illegitimate | illegitimate, localPartSpamTrap, profanity | Reject | Suppress from campaigns and customer communications. Investigate source quality if volume is material. |
Illegitimate | roleAccount | Industry Dependent | Accept only where a shared mailbox is appropriate, such as some B2B or support use cases. Reject or review for personal, healthcare, financial, or identity-related use cases. |
Illegitimate | typoDomain | Correct and Retest | Use the suggested correction only after retesting and confirming the corrected email validates appropriately. |
Disposable | disposable | Reject | Do not use for ongoing customer communications, account verification, or regulated communications. |
Unknown | unknown, timeout, relayDenied, blank | Retest / Conditional Accept | Use only where business risk is low. Retest before critical use. Monitor bounce and engagement results. |
Unknown | acceptAll | Conditional Accept | The domain accepts all emails, so mailbox-level confirmation is not conclusive. Accept for low-risk marketing only; do not rely on it for critical notifications. |
Recommendation Values
Use a controlled list of recommendation values so the output is consistent and easy to operationalise.
Recommendation | Meaning | Typical Downstream Action |
Accept | Result is suitable for the intended use case. | Use the email or phone number. |
Conditional Accept | Result is not fully confirmed but may be usable for low-risk purposes. | Use with controls, such as bounce monitoring, consent checks, and fallback channel. |
Retest | Result may be temporary or inconclusive. | Revalidate before using, especially if the record is valuable or the communication is important. |
Correct and Retest | A suggested correction exists but should not be trusted automatically. | Apply the correction to a separate field, retest, and only promote if verified. |
Review | Human or business-rule review is required. | Send to data stewardship, contact centre, CRM queue, or operational review. |
Reject | Result is unsuitable for the intended use case. | Suppress from the relevant channel and request updated details. |
Handling Experian Confidence Levels
Experian validation confidence should be interpreted as a contactability indicator, not as proof of customer identity or permission to contact. The confidence level should be combined with consent, purpose of communication, channel, customer value, and industry risk.
The source guidance for phone validation includes a recommendation table where some results are clearly accepted or rejected, while others vary by context. It also explicitly states that the table should be used as a guide and that the best approach should be confirmed with the client for each response type and confidence level.
Suggested Confidence Handling Framework
Confidence Category | Email Examples | Phone Examples | Recommended Approach |
High confidence contactable | Verified | Live, Verified Mobile | Accept for the approved use case. |
Temporary or inconclusive | mailboxFull, timeout, unknown, acceptAll, relayDenied | Absent Subscriber, Unknown, Inconclusive, No Coverage | Retest, conditionally accept, or route to alternate channel depending on risk. |
Hard failure | mailboxDoesNotExist, mailboxDisabled, syntaxFailure | Dead, Bad Format, No Teleservice Provisioned | Reject for that channel and request updated details. |
Risk indicator | spamtrap, disposable, profanity, illegitimate | Premium, Shared Cost, Pager, Voicemail Only, Stage and Screen | Reject or review depending on policy. Usually suppress from automated use. |
Context-dependent | roleAccount, acceptAll | Landline, VoIP, Personal Number, Mobile or Landline | Apply industry and use-case rules before deciding. |
Phone Recommendation Summary
The phone validation article provides a useful baseline for handling common phone confidence outcomes. Mobile numbers with Verified or Absent outcomes are generally recommended as Accept, while Dead, No Teleservice Provisioned, Bad Format, Premium, Toll Free, Shared Cost, Pager, and Voicemail Only outcomes are generally recommended as Reject. Some outcomes, such as Landline, VoIP, Personal Number, and Mobile or Landline, are marked as Varies and should be assessed against the intended use case.
Phone Type / Status | Baseline Recommendation | Suggested Handling |
Mobile / Verified or Live | Accept | Suitable for SMS or call use, subject to consent and communication purpose. |
Mobile / Absent Subscriber | Accept or Conditional Accept | May be acceptable for marketing or low-risk contact; retest for critical communications. |
Mobile / Unknown | Conditional Accept | Use for lower-risk use cases only; monitor failures and retest periodically. |
Mobile / Dead | Reject | Suppress from phone use and request updated number. |
No Teleservice Provisioned | Reject | Do not use for calls or SMS. |
No Coverage | Industry Dependent | Retest or use alternate channel. Reject for high-risk use cases. |
Inconclusive | Review / Retest | Do not rely on for critical communications. |
Landline | Varies | Accept for voice calls if appropriate; reject for SMS-only use cases. |
VoIP | Varies | May be acceptable for service calls, but review for identity, OTP, or regulated use cases. |
Premium, Shared Cost, Toll Free | Reject | Usually unsuitable for customer contact records. |
Bad Format | Reject | Standardise, correct if possible, then retest. |
Industry-Specific Recommendation Policy
The same Experian result can lead to different recommendations depending on industry and communication purpose. The recommendation column should therefore be generated using a policy profile.
Industry / Use Case | Recommended Strictness | Email Handling | Phone Handling |
Healthcare – clinical, appointment, patient safety, care instructions | High | Accept Verified only. Reject or manually confirm Unknown, Disposable, Illegitimate, Role Account, Undeliverable, and Unreachable before use. | Accept Live or Verified mobile only for critical communication. Review or confirm Absent, Unknown, Inconclusive, No Coverage, VoIP, and Landline depending on channel. |
Healthcare – general engagement or wellness campaign | Medium | Accept Verified. Conditional Accept for acceptAll or timeout only where consent exists and the message is low-risk. Reject Disposable, Spamtrap, Illegitimate, and Undeliverable. | Accept Verified or Live mobile. Conditional Accept for Absent or Unknown if campaign risk is low. |
Marketing / Retail campaigns | Low to Medium | Accept Verified. Conditional Accept for Unknown, acceptAll, mailboxFull, or timeout with bounce monitoring. Reject Disposable, Spamtrap, Profanity, and mailboxDoesNotExist. | Accept Verified, Live, Absent, and sometimes Unknown mobile numbers where consent exists. Reject Dead, Bad Format, Premium, Shared Cost, and No Teleservice. |
Financial Services / Insurance | High | Accept Verified for regulated, transactional, or account-related messages. Review or reject Unknown, acceptAll, Role Account, Disposable, and Illegitimate. | Accept Verified or Live mobile for customer contact. Retest or confirm uncertain results before OTP, collections, claims, or regulatory notices. |
Government / Utilities | Medium to High | Accept Verified for service notices. Retest or review inconclusive results. Use postal or call-centre fallback for important notices. | Accept Verified or Live mobile. Treat No Coverage, Unknown, VoIP, and Landline according to the communication channel and obligation. |
B2B / SaaS | Medium | Accept Verified. Role accounts may be acceptable for support, procurement, or general enquiry use cases. Reject Disposable and spamtrap indicators. | Accept verified direct numbers. Review shared, VoIP, or generic numbers depending on sales, support, or billing use case. |
Example: Same Result, Different Recommendation
Validation Scenario | Healthcare Recommendation | Marketing Recommendation |
Email result is Unknown / acceptAll | Reject for clinical or patient safety communication. Use alternate channel or confirm with patient. | Conditional Accept if consent exists. Send with bounce monitoring and fallback rules. |
Email result is mailboxFull | Retest or confirm before sending important information. Do not rely on it for critical communication. | Conditional Accept or Retest. May remain in campaign audience temporarily. |
Email result is roleAccount | Reject or Review for patient-specific communication because it may not identify an individual recipient. | Accept for B2B marketing or general business contact if appropriate. |
Phone result is Mobile / Absent Subscriber | Review or Retest before critical communication. Use alternate channel if needed. | Accept or Conditional Accept for low-risk campaign use. |
Phone type is VoIP / Verified | Review for identity, OTP, or regulated use cases. | Accept for general contact or service follow-up if appropriate. |
Email result is Disposable | Reject. | Reject. |
Phone result is Dead | Reject. | Reject. |
Recommended Contact-Level Decisioning
The best output is not only an email recommendation or phone recommendation, but an overall contact recommendation.
Email Recommendation | Phone Recommendation | Contact Recommendation |
Accept | Accept | Use preferred channel based on consent and communication type. |
Accept | Reject | Use email; request updated phone number. |
Reject | Accept | Use phone; request updated email address. |
Conditional Accept | Accept | Prefer phone for important communication; email may be used for low-risk messages. |
Accept | Conditional Accept | Prefer email for important communication; phone may be used with controls. |
Retest / Review | Retest / Review | Hold from critical campaigns and route to data quality review. |
Reject | Reject | Suppress from automated contact and trigger data capture or remediation process. |
Practical Rules for Applying Suggested Email Corrections
Suggested corrections should be handled carefully because the source guidance states that a correction may not always be the correct email to use going forward.
Recommended approach:
Scenario | Suggested Action |
Suggested correction exists and corrected email validates as Verified | Accept corrected email, but retain original value for audit. |
Suggested correction exists but corrected email is Unknown or Unreachable | Do not automatically replace. Retest or review. |
Suggested correction changes the domain materially | Review before updating, especially in healthcare, finance, government, or regulated use cases. |
Suggested correction applies to obvious common typo, such as a known mailbox provider typo | Correct and retest before use. |
No correction exists and result is Undeliverable or Syntax Failure | Reject or request updated email. |
Recommended Governance Approach
To make recommendations reliable and auditable:
Governance Step | Recommendation |
Preserve raw results | Keep Experian validation result, verbose result, confidence, and correction fields unchanged. |
Add derived recommendation fields | Append recommendation columns rather than overwriting source data. |
Apply industry policy | Use different rules for Healthcare, Marketing, Financial Services, Government, B2B, and Retail where required. |
Retest uncertain records | Retest Unknown, timeout, mailboxFull, relayDenied, Inconclusive, and No Coverage results before important use. |
Monitor outcomes | Track bounces, SMS failures, call failures, complaints, and unsubscribe rates. |
Confirm client rules | Agree which results should be accepted, rejected, or reviewed before operationalising the output. |
Avoid permanent suppression for temporary states | Results such as mailboxFull, timeout, Absent Subscriber, or No Coverage may change over time. |
Separate contactability from consent | A valid contact point does not mean the organisation has permission to use it. |
Suggested Default Recommendation Logic
The following default logic can be used as a starting point.
Result Type | Default Recommendation |
Email Verified | Accept |
Email Undeliverable due to mailboxDoesNotExist, mailboxDisabled, or syntaxFailure | Reject |
Email Undeliverable due to mailboxFull | Retest |
Email Unreachable | Retest / Review |
Email Disposable | Reject |
Email Illegitimate due to spamtrap, profanity, inactive domain, or black hole | Reject |
Email Illegitimate due to roleAccount | Industry Dependent |
Email Unknown due to timeout, acceptAll, relayDenied, or blank | Conditional Accept for low-risk use; Retest or Reject for high-risk use |
Phone Mobile Verified / Live | Accept |
Phone Mobile Dead | Reject |
Phone Mobile Absent | Accept for low-risk use; Review for high-risk use |
Phone Unknown | Conditional Accept or Review |
Phone No Teleservice Provisioned | Reject |
Phone No Coverage | Industry Dependent |
Phone Landline / VoIP / Personal Number | Varies by use case |
Phone Premium / Shared Cost / Toll Free / Pager / Voicemail Only | Reject |
Assumptions, Risks, and Open Questions
Category | Notes |
Assumptions | The organisation has already captured consent and lawful basis for the intended communication. Validation results are being used for contactability and data quality decisioning, not identity verification. |
Risks | Real-time validation results can change. Overly strict rules may remove usable contacts. Overly permissive rules may increase bounce rates, failed messages, privacy risk, or poor customer experience. |
Missing Evidence | The final recommendation rules should be confirmed against the client’s industry, communication purpose, consent model, risk appetite, and channel strategy. |
Questions to Confirm | Which communications are critical versus promotional? Which industries or business units need stricter rules? Should Unknown be accepted, retested, or rejected? How should corrected emails be approved? What retention and audit requirements apply? |
Recommended Position
Use Experian validation confidence levels as a decision-support input, not a universal pass/fail rule. Create an EDQ Email Recommendation column and align it with the existing phone recommendation approach. Apply a default recommendation first, then adjust it using an industry policy overlay.
For healthcare, financial services, government, and other high-risk use cases, use a stricter model: accept only high-confidence contact points and route uncertain results to review or confirmation. For marketing and retail campaigns, use a more flexible model: accept verified contacts, conditionally accept some uncertain results, and suppress clear risk or failure indicators.
