Joining Data example for Purchase Order Headers and Lines
Clinton Jones
Experian Elite
This workflow uses PO sample data
The PO header and rows, is joined using the order number
This workflow performs a date calculation, adds an average aggregation based on a product ID grouping and then produces a reduced list of records sorted by average days to fulfil.
You could consider this as a simple report workflow to indicate which products are fulfilled fast and which products take longer to fulfill as an example. The group step also hides columns
