Having problems with connecting to a new instance of D365
Have set up a new connection to a different D365 instance in the same environment and getting the following error Caused by: com.experian.aperturedatastudio.jdbc.dynamics365.phoenix.sql.ae: The specified session options do not match the options used to initially create the schema map. Either change the option values or specify a new schema map: Only thing different is a slightly different URL - same ID, same secret.
