Highlight steps connection in Read Mode
Fuks, Emilia (GB)
Contributor
What problem are you facing?
Users without edit permission can't trace the flow between workflow steps in large workflows.
It would be useful if the lines could be highlighted when clicked on (like in edit mode).
It impacts productivity, takes a long time to trace the process and makes it sometimes impossible to confirm if connections between steps are correct.
No.
Highlight lines when clicked on.
6
