UX Improvement - Output label case sensitive
Fuks, Emilia (GB)
Contributor
What problem are you facing?
The Workflow step output names/labels are being all converted to lower case when the reusable workflow is added inside another workflow.
It makes it more difficult to distinguish between outputs, especially when there are several, which are named similarly.
No, it is not possible to make the output label case sensitive.
Make the labels case sensitive. To keep the text formatting of the output step.
