No JDBC option for external system
James T Sidebotham
Contributor
in Support
Hi, any reason why I would not have a JDBC option in the drop down for creating an external system?
Hi James
Could be a few different reasons, but most likely is that you do not have any JDBC drivers installed or the location they are loaded to is not the 'standard' folder and is not mapped correctly:
Thanks Josh
