Aurora database connection?
Nigel Light
Contributor
Our client MDM has been built on an aurora database platform. Is there a connector for Aperture to this source?
Nige
"You can connect to an Aurora DB cluster using the same tools that you use to connect to a MySQL or PostgreSQL database." https://docs.aws.amazon.com/AmazonRDS/latest/AuroraUserGuide/Aurora.Connecting.html
So if it is as compatible as Amazon suggest then you should be able to use the MySQL or Postgres driver (depending on which you are using). https://docs.experianaperture.io/data-quality/aperture-data-studio-v2/uncategorized/use-jdbc/
If you run into any issues then you can let us know.
