Anyone got the Azure Blob Storage Datasource connection working
If so, what URL did you use?
Couldnt find documentation around this.
Thanks for answering
Clinton Jones Administrator
Sorry, I confused myself I read AWS S3 and that was what i was looking at
I just tested this on v1.6.2 (should still hold true for v1.6.3
5
is this the message you get ?
despite passing the setup sniff test ?
It kinda hangs on the 'Test Connection' doesn't return.
I'm on 1.6.3, curious if anyone has got it working
Please open a support ticket for this for investigation, it was working I don't believe it has regressed.
just another thing if you're doing this via a VPN you may have a blocked connection to AWS, so worth checking
Thanks for your help, I managed to create the datasource connection
