Inferring Gender from Title or Honorific and Gender Reversal
Clinton Jones
Clinton Jones Experian Elite
Sometimes it might be useful to determine the gender of a person from their honorific, so for example deciding that the greeting should be Sir or Madam depending on the Mr or Mrs or Miss honorific.
The interesting aspect of this inferral task is that in Data Studio there are a good many ways that you can achieve this result.
Here's one that uses the EQUALS condition evaluation and IF THEN ELSE operators
The result is then as follows
You can also look at using lookups but this would require you to have a lookup list that has both Honorific and Saluation in the same dataset.
Is there another way you could do this, perhaps using a regular expression?
  • Nigel Light
    You might hit trouble when eg you start getting military rankings, clergy eg Major Smith, The Right Reverend Green - Male or Female?
    The recent adoption of Mx causes similar issues too..
  • Clinton Jones
    @Nigel Light yes that is a good point but then you might use a combination of conditional IF then logic. Most important though, is aside from the use of a lookup, is this really the only way to determine an appropriate salutation?
  • Nigel Light
    Lookup table?
    It would then allow the table to be used in other applications and promote improved governance rather than hard-coding in the program itself
    Nige
  • Clinton Jones
    Yes, you could consider something that appends a salutation based on the honorific identified
