Row Quality is not accurate
Postcode | Postcode - Weight | Postcode should not be null for a UK address | Postcode should be a valid UK postcode | First Address Line | First Address Line - Weight | First Address Line should not be null | First Address Line should not contain special characters | Primary Email address | Primary Email address - Weight | Primary Email Address should not be null | Primary Email Address should be in a valid format | Internal Reference | Internal Reference - Weight | Internal Reference should not be null | Country of Tax Residence | Country of Tax Residence - Weight | Country of Tax Residence should not be null | External Reference | External Reference - Weight | External Reference should not be null | External Reference should be in a valid format | Row quality |
Pass | 1 | Pass | Pass | Pass | 1 | Pass | Pass | Fail | 1 | Fail | Ignore | Pass | 1 | Pass | Pass | 1 | Pass | Pass | 1 | Pass | Pass | 88.89 |
Hi, have a look at this example above. This data has been copied and pasted from a validate step choosing the option 'Show all rows'. Why is the row quality 88.89% rather than 90%? There are 10 rules and only 1 of them failed for this particular row.
Postcode
Postcode - Weight
First Address Line
Internal Reference
External Reference
Row quality
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Pass
Fail
Pass
Fail
90
Here's another row example from the same validate step. This row has also failed only 1 rule, and the row quality is 90% which is expected.
There are 9 rules, not 10, as 'Primary Email Address should be in a valid format' has returned 'Ignore' for this row.
1 / 9 = 0.1111 »» 100 - 11.11 = 88.89
I see. This affects the solution you mentioned here (I can't seem to comment on my other post):
Is there a way to replicate the COUNTIF formula? — Experian Data Quality Community
In one of the steps I need to specify the number of rules, but how can I do that dynamically for each row, taking into account any ignored rules in each row?
Suggested another approach in that thread using Replace and Add
