Row Quality is not accurate
Postcode
Postcode - Weight
Postcode should not be null for a UK address
Postcode should be a valid UK postcode
First Address Line
First Address Line - Weight
First Address Line should not be null
First Address Line should not contain special characters
Primary Email address
Primary Email address - Weight
Primary Email Address should not be null
Primary Email Address should be in a valid format
Internal Reference
Internal Reference - Weight
Internal Reference should not be null
Country of Tax Residence
Country of Tax Residence - Weight
Country of Tax Residence should not be null
External Reference
External Reference - Weight
External Reference should not be null
External Reference should be in a valid format
Row quality
Pass
Pass
Pass
Pass
Pass
Pass
Fail
Fail
Ignore
Pass
Pass
Pass
Pass
Pass
Pass
Pass
88.89
Hi, have a look at this example above. This data has been copied and pasted from a validate step choosing the option 'Show all rows'. Why is the row quality 88.89% rather than 90%? There are 10 rules and only 1 of them failed for this particular row.
  • Postcode
    Postcode - Weight
    First Address Line
    Internal Reference
    External Reference
    Row quality
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Pass
    Fail
    Pass
    Fail
    90
    Here's another row example from the same validate step. This row has also failed only 1 rule, and the row quality is 90% which is expected.
    There are 9 rules, not 10, as 'Primary Email Address should be in a valid format' has returned 'Ignore' for this row.
    1 / 9 = 0.1111 »» 100 - 11.11 = 88.89
  • I see. This affects the solution you mentioned here (I can't seem to comment on my other post):
    Is there a way to replicate the COUNTIF formula? — Experian Data Quality Community
    In one of the steps I need to specify the number of rules, but how can I do that dynamically for each row, taking into account any ignored rules in each row?
    Suggested another approach in that thread using Replace and Add
