How to handle a table with more than 500 columns using 'rows to columns' object?
Hello it is possible to update the 100 column limitation if needed, but note the warning about potential performance degredation.
"By default, up to 100 new columns are allowed, the first 5,000 rows will be sampled, and the timeout is 10 hours. You can change these defaults in the server.properties file. Note that changing some of these values may affect Data Studio performance."By default your Server.properties file would be found in the installation directory C:\Program Files\Experian\Aperture Data Studio <version>. Once you have updated the file you will need to restart the Server
Thank you. We'll look into it. We find work around, using Sample step.
