Add object tags for charts
Simon_
Simon_ Member
edited November 2025 in Ideas board
What problem are you facing?
Unable to add an object tag to a chart.
We use tagging to quickly identify where a view or dataset is used (e.g. what dashboard it sits in), without having to open associations for each one. We are unable to do this for charts as there is no option to tag a chart.
Add the dashboard to the description. This isn't as nice as using tags, as each description still needs to be read.
2 votes
  • Mirjam Schuke
    Mirjam Schuke Administrator
    I can add this to the priority list now that you told us this would be helpful. We had started with the most used objects first. Other users please vote, if you would find this helpful as well.
