'Time period for all events to occur' box within automations
Is anyone able to explain what the : ''Time period for all events to occur' does? within the automations part of ADS
If i set this to 1 and it takes more than 1 min for the above actions to finish what will happen?
likewise if i set it to 10 mins and it finishes in 5 will that 'pass'?
Many thanks,
    edited November 2025
    The setting/box is shown once you have more than one event.
    Fewer minutes that specified with all events occuring will pass and trigger the Automation.
    The Automation will not trigger if more minutes have passed between the first event and last event happening than you specified. Or you can use the checkbox to ignore the timing and trigger if any of the selected events occur.
