Possibility to configure workflow report download destination?
Workflow report gives very good information about the details related to the workflow.
Is it possible to configure workflow report to some common destination or use the URL of that report directly? It would be very valuable for the documentation purposes to get that kind of information automated.
I would like this too. The report is a great tool for audit and lineage, would be good if we can put it in a workflow and export somewhere.
Hi Katri, please can you add this as an Idea?
Rather than "configuring a download destination", what is the problem you would like solved? Who are the users that want to look at this 'documentation'? Do they only ever want to see the latest or should there be a periodic audit trail etc?
If it was possible to get a Workflow report from an API call would this solve the problem to be able to automate this process?
For me, if I was able to run it the same way that I run other APIs such as "/api/default/datasets/" using CURL then that would work for my needs. But I am just one voice.
@Josh Boxer Yes, API call would solve this problem, thanks! It would be easier to share the documentation about workflows and the documentation would then also be up to date.
