Upgrading Experian Aperture Data Studio from v2 to v3
We are planning to upgrade our Experian Aperture Data Studio from v2.14.14.40 to the latest v3 and Find Duplicates Standalone from v3.11.2 to v3.14.5
We are already using cloud licensing and have also connectivity to the entitlement url https://entitlement.saas.edq.com/api/v1/EntitlementCheck.
Could you please let me know if any other pre-requisites need to be checked? Also are there any changes/regression tests needed for existing workflows created in v2 after upgrading to v3 or for the standalone find Duplicates configuration?
Hello, I am unaware of any other pre-requisites. Yes we ensure that releases are tested against older versions to prevent any breaking changes
Thanks for checking on this.
I have one more query, is there an update to the REST APIs that would allow us to create datasets from JDBC type of external system with SQL query as well as bulk datasets creation that we are currently able to do from UI?0 -
Create Datasets API was enhanced in v2.15.8 to create from a database table, but you cannot include a SQL query at this time:
