Sticky Notes attached to Workflow step
James T Sidebotham
edited September 2024 in Ideas board
Just a thought… but it would be really nice if Sticky notes could be pinned to workflow steps (I always provide decisions or descriptions of steps as part of knowledge transfer). That way if I move my workflow step the Sticky note comment moves with it (or worse, someone hits the auto-arrange button and now my Sticky notes have no context). Also when I create the workflow report if the Sticky note can be included in that step, that would be helpful. Any Sticky notes not attached to a step can simply be listed at the bottom of the report.
4 votes
    James I converted this to be an Idea to see if others would find this useful. Internally we have previously discussed 'containers' similar to a note but containing one or more steps.
    In the meantime, if you give a note a description then it appears attached to a step. More limited than a sticky note, but might be useful in some situations.
  • Ian Buckle
    I Agree when workflow building and adding notes I'm often referencing a step or sections of a workflow. Being able to attach this to them would prevent accidental re-arrangements causing the note to move to a different part of the workflow that it is not relevant for, especially in scenarios where workflows change hands/worked on by multiple users and they may not know this has happened.
  • Came to suggest something similar in terms of sections. I think effectively, in my head anyway, the current sticky notes - but able to be made into a significantly larger size and sit behind the workflow steps - would work.
