Pushdown Processing on a pivot
In testing Pushdown Processing today, I hit a couple of errors.
The first is simple to workaround by removing it (but would be awesome if the generation understood to omit) - the dataset query had a semi-colon at the end, which pushdown processing then put it's "as R0" after:
The second I'm still at a bit of a loss. I have another dataset that has similar columns:
"* Private Client"
"Private Client"
The issue is the generator seems to be effectively ignoring the "* " (maybe because of *'s significance in SQL as select all?) and therefore treating the column name as a duplicate, generating this SQL:
"'Private Client' 1" not being a column then causes the pushdown processing to error. The dataset column names are generated from a pivot, so I need to keep the naming convention ideally, to avoid hardcoding a fix and losing the convenience of the pivot.
TLDR: can the pushdown processing SQL generation be tweaked to handle semi-colons at the end of the query, and handle datasets where column names are identical, but for some text that's being ignored (in this case is "* ")
Mike
    Thanks Mike for the feedback. If you please can share a dmx file containing the Workflow and Dataset(s) [no data] that will help to investigate
  • Hi Josh,
    Neither issue passes a source step, so the DMX wouldn't show much at all. I tinkered more and discovered it's not so much a pushdown issue directly, but a dataset one.
    For the first "issue" (definitely a lesser concern as removing a character from a dataset is no real fuss!), replicated by creating a dataset connecting to Snowflake external system with a query as follows:
    select * from someTable;
    It will work fine - unless you try to pushdown process.
    Second issue I think is more legitimate - When you create a dataset using a pivot from Snowflake, it changes the name of the column on the dataset (for the below example, it will rename what natively ran in Snowflake produces a column 'Private Client' as 'Private Client' 1). Again, works in general usage, but errors on pushdown as the SQL generated contains a reference to the numbered name.
    To replicate, you can create a dummy table in Snowflake as below, and pictures below that show the difference in the Snowflake output vs the Dataset output of column names:
    create or replace temporary table MadeUpMarkers
    id number
    , MarkerType varchar(30)
    insert into MadeUpMarkers
    values
    (1, '* Private Client')
    ,(2, 'Private Client')
    -- this is the query that would live within Aperture to call and pivot the table
    select *
    from
    select *
    from MadeUpMarkers
    pivot (
    max(id)
    for MarkerType IN (ANY)
    ) as PivotTable
    Quite niche…. but thought worth raising in case it can help make the dataset creation even more robust to horrid data values!
    Mike
