A default value for "automatically delete data after N days"
Henry Simms
What problem are you facing?
Almost all the data loaded into my Data Studio instance has a mandated 90 day retention period. 90 days after load we want to delete any batches that remain. Most data is loaded into new Datasets (in new Spaces) because we are working typically on short-term, one-off projects.
There are exceptions to this (eg static domains / lookup tables).
While Data Studio has a "Automatically delete older batches after N days" option, it needs to be explicitly set for each new Dataset that is created. Often, users do not remember to set the "delete after N days" value on all Datasets created for a given project.
The users have to set reminders to either manually review all Datasets to check they have the correct "delete after N days" value set, or to manually delete batches as required. This is time consuming but also error-prone. There is a risk that data is not deleted when it is supposed to be, and in turn that data retention policies are not met.
As described above, lots of manual review to ensure data is deleted as necessary.
Suggestion is a default value for "automatically delete data after N days", which may be set at the global, environment, or space level (I don't know which makes most sense). Rather than having to set the "deletion in N days" value manually per-dataset, I'd like (to meet data retention requirements) to be able to set a default that's applied for any new Dataset, and to only turn it off for specific datasets as an exception.
5
5 votes
Now available · Last Updated
Will be available from 2.15.4
  • Ivan Ng
    Ivan Ng Administrator
    Hi Henry,
    Thanks for the suggestion. I will review this and be in touch for further details. Thanks.
    Related request is an option to not allow the default value be overridden at the Dataset level
  • Ian Hayden
    @Henry Simms @Josh Boxer @Ivan Ng Hi all, @Jacky Lu has raised that the implementation does not cascade the global 'N Days' setting to newly created snapshots. Was this by design, or was it just not considered for this request?
    @Ian Hayden By default I'd have expected the setting to apply to Snapshots as well as loaded Datasets
  • Ivan Ng
    edited September 12
    @Ian Hayden @Henry Simms As of now, this setting only covers datasets and not snapshots. I will put in another request to extend the setting to snapshots as well.
