How to explore Workflow script (preview) functionality
Karthik_Anbusekar
edited August 26 in General
Recently we upgraded to experian 3.1, and i would like to try Workflow Scripting (preview). But i unable to find those feature. Can anyone please help me with this?
    edited August 28
    Hello Karthik
    The Workflow scripting feature is in Preview, but you can enable it by creating a text file called devfeatures.properties containing the line workflowscripting=true and saving this file where your server.properties file is located (by default, this will be C:\Program Files\Experian\Aperture Data Studio {version}) then restart the service Experian Aperture Database Server.
    Once enabled you will see a script box option on the Create Workflows screen:
    The script language to use is PRQL, reference: https://prql-lang.org/book/
    The following PRQL commands/transforms are supported:
    PRQL transform
    Purpose
    Workflow step
    from
    Specify data source (using External Label)
    Source
    derive
    Compute new columns
    Transform
    select
    Select, compute and rename columns
    Transform
    filter
    Select rows based on their value
    Filter
    sort
    Order rows based on the value of columns
    Sort
    join
    Match two sources
    Join
    take
    Pick rows based on their position
    Sample
    group
    Partition rows in to groups
    Group
    aggregate
    Summarise many rows in to one row
    Group
    append
    Concatenates two sources
    Union
    Also the PRQL variables let and into. Plus the following Workflow steps that are are not in the standard PRQL definition: takesnapshot <existing Dataset external label> and export csv/txt/xls/xlsx/json
    edited August 28
    A few examples
    from SODetail
    derive Total_Value = Price * Quantity
    sort {-Total_Value}
    take 20
    from SODetail
    sort {-Total_Value}
    take 20
    from Customers
    filter Country == "United Kingdom"
    into UKCustomers let HighValueCustomers = (
    from Customers
    filter Country != "United Kingdom" && Sales Last Year > 1000000
    ) from UKCustomers
    append HighValueCustomers derive Contact_Name = f"{Forename} {Surname}"select !{Forename, Surname, Discount Code}
    export csv
    Feel free to share any questions or feedback. If more examples are needed then let me know.
