How to explore Workflow script (preview) functionality
Hello Karthik
The Workflow scripting feature is in Preview, but you can enable it by creating a text file called
devfeatures.propertiescontaining the lineworkflowscripting=trueand saving this file where yourserver.propertiesfile is located (by default, this will be C:\Program Files\Experian\Aperture Data Studio {version}) then restart the service Experian Aperture Database Server.Once enabled you will see a script box option on the Create Workflows screen:
The script language to use is PRQL, reference:
The following PRQL commands/transforms are supported:PRQL transform
Purpose
Workflow step
from
Specify data source (using External Label)
Source
derive
Compute new columns
Transform
select
Select, compute and rename columns
Transform
filter
Select rows based on their value
Filter
sort
Order rows based on the value of columns
Sort
join
Match two sources
Join
take
Pick rows based on their position
Sample
group
Partition rows in to groups
Group
aggregate
Summarise many rows in to one row
Group
append
Concatenates two sources
Union
Also the PRQL variables let and into. Plus the following Workflow steps that are are not in the standard PRQL definition: takesnapshot <existing Dataset external label> and export csv/txt/xls/xlsx/json
A few examples
from SODetail derive Total_Value = Price * Quantity sort {-Total_Value} take 20from SODetail derive Total_Value = Price * Quantity
sort {-Total_Value}
take 20from Customers
filter Country == "United Kingdom"
into UKCustomers let HighValueCustomers = (
from Customers
filter Country != "United Kingdom" &&Sales Last Year> 1000000
) from UKCustomers
append HighValueCustomers derive Contact_Name = f"{Forename} {Surname}"select !{Forename, Surname,Discount Code}
export csvFeel free to share any questions or feedback. If more examples are needed then let me know.
Thank you @Josh Boxer
