Find Duplicates - Ignore a value
I am attempting to use the find duplicates module. In one of my unique data fields I have dfound that a dummy value has been used for cases where data is not easily obtainable. Is there a way to direct the matching criteria to ignore this value when trying to match rows?
Column name in Data is 'UniqueID'
TIA.
Hi, our usual approach here is to cleanse the data beforehand and remove any information not suitable for matching. You could apply a simple 'if then else' function to replace 'UniqueID' with NULL.
I've attached a .dmx with a function you can use. You'll need to be on version 2.16.9 or later to import it.
