QAS Vs Experian Aperture Address Validation
We currently use QAS for address validation and currently running POC for Aperture data Studio. Please can you share the benefits of using QAS over Aperture for address validation. Is there any difference in the way address is validated in QAS and Aperture.
Thanks,
Jencil
Hi Jencil
Aperture uses the Batch API product under the hood, so is very similar in terms or functionality and results:
However, since the standalone Address product has been developed over many years there might be something you rely on that is not yet supported.
Best option is probably to speak with your Experian contact who will be able to help you compare for your use cases at a granular level.
