Percentile calculation
Alfredo Monasi
Experian Employee
Hi everyone, I created a reusable workflow that define wheter a column value is in the 'Percentile' value (for example 95%) or not and also creates a column indicating if you need to smooth a value when reach or surpass that percentile.
It needs a column and a parameter to the percentile to calculate (1%, 5%, 25%, 50%, 75%, 90%,95%… 100%)
Hope it helps someone as helped me!
Fab. Thanks for sharing @Alfredo Monasi!
