XML driver for Aperture
Nigel Light
Nigel Light Contributor
Does anybody on the forum know if it is possible to read semi-structured XML data into Aperture?
If so, how do we do this? (and is it 'out of the box'?)
Nige
  • Akshay Davis
    Data Studio has the concept of Custom Parsers, and the JSON parser is included as an example of this. XML parsing follows a similar process, but there isn't an parser which is included to do this.
    Others may have created a custom parser to handle XML though.
  • Thanks Akshay - are there any plans to develop one in the future for future releases?
  • Clinton Jones
    Clinton Jones Experian Elite
    @Pavan Rao can connect you with Jacky Lu within the UK services team that have an XML parsing custom step that they have developed as custom. I am not sure how easy/difficult it would be for them to adapt it to your needs @Nigel Light
  • Clinton Jones
    @DTAconsulting I'll get Doug to reach out to you
  • Nigel Light
    Thanks Clinton - I'm not on this at the moment (just a question that somebody had last Autumn)
