Add record limit to source step
Emilia Fuks
Emilia Fuks Contributor
edited June 25 in Ideas board
What problem are you facing?
Working with very large datasets, sometimes hundreds of millions of records, in order to debug a workflow, I often find myself adding a sample tool after each source so that I can preview results at different steps in the workflow. Otherwise it can take hours waiting for 'show step results'. It is a slow process, since the sample tools need to be reconnected with the other tools in the workflow.
It affects efficiency and user experience.
Workaround is to add a sample step after every source step.
Add an option to limit the number of records in the source step.
5 votes
  • Mike Pearson
    Mike Pearson Contributor
    Great idea. We've certainly had the same when trying to quickly debug a flow
  • This would be very convenient for debugging without having to add new Steps. I like it!
