How to modify in aperture the header for Powercurve Collections interfaces
I am working on the input interfaces that PCC manages, which has the following nomenclature
ProcessingDate|Row-count
Here is an example:
20250603|5762202
1416|81178235||Vendor||
6700|81380685||Sold-From Party||
but I can't get the columns to join correctly. as a result I have this
20250603|5762202||||||
do you know what component I can use to edit the header correctly?
Hello, not sure I understand the question being asked here but I think you are trying to Union datasets (that have columns with different column names)?
Please provide more detail, might even be better to start a new discussion keeping it more generic: input(s) look like this… then desired output should look as folllows…
