Column header in the second row
Hi All,
is there a way to use the second row (instead of the first) as the column names when uploading dataset? Or is there a workaround?
There is a dataset that we would like to drop into the DropZone but the header is always in the second row…
Many thanks!
Vera
You can if the filetype is delimited rather than Excel:
(possibly not in your older version)
Hi Josh,
ah yes, thanks with .txt it has the option to select!
Many thanks!
