Tagging as sensitive information
Hi All,
As I'm reviewing the space settings, I noticed there is a section called "Potentially Sensitive Information."
Could you please let me know how to tag specific columns in a dataset or view as sensitive data?
In some cases, we need to create restricted views, so it would be helpful to have a clear way to identify these columns and the related datasets/views.
Thanks in advance for your support!
Kind regards,
Vera
    edited May 2025
    Hello
    Go to Datasets and select 'Annotate columns' for a specific Dataset [note this is also shown as one of the steps when adding a new Dataset]. You can add Data tags to columns automatically and/or manually (another option is to do this in bulk using API, but would require an upgrade to a recent version for this API functionality). Data tags that are 'sensitive' that are applied to columns will warn that the Dataset contains sensitive data.
    https://docs.experianaperture.io/data-quality/hosted-aperture-data-studio/admin-setup/data-tags
  • Vera O
    Vera O Member
    edited May 2025
    Hi Josh!
    Great and I could also create a new tag and indicate as sensitive!
    Can we extract somehow this information with API which dataset columns are tagged?
    Many thanks!
    Vera
