Configuration of Line Endings in Export Step
What problem are you facing?
The option to select what type of Line ending that should be applied to an export
Different clients have requests on the specific file format they want depending on how they load these files. There are some that request their files with Windows line ending and others Unix line endings and not having this option means we cannot deliver as agreed.
No workaround on the current version but Aperture v1 had options in the export step to specify different line endings.
Add the option to select what Line Ending to apply to a file in the export step.
My understanding is that a custom step has been created to achieve this. Closing for now but could re-open if required or if there are other customers in future who might find this useful.
