On Schedules List Screen - Include whether Refresh Sources
What problem are you facing?
On the schedules list screen, I have to go into each individual item to confirm if 'Refresh Sources' and what type of schedule has been configured (Refresh dataset or Run workflow).
Ease of use impacted. Having 'Refresh Sources' and 'Task Type' provides better way to confirm settings - and also prevents accidently changing settings when going in to check details.
Go into each schedule - which can be time-consuming if many have been added.
Add columns indicating 'Refresh Sources' and 'Task Type'
Noting a workaround for doing things at scale is to use the API:
