Set Space & Dashboard as a default?
James T Sidebotham
Contributor
in General
Is it possible or has it been discussed about having the option to specify a Space and Dashboard as a default at log-in?
Hi James
You can configure your Homescreen widgets if this is what you wanted to see on login. You can also drag the tabs to change the order so that the first Dashboard will be the one a Consumer user sees when they login:
Yeah but if I have a team dashboard that I want to set as the default for several team members I cant do that, right? Would be nice if in each space a dashboard has the ability to be the default displayed (set as the 'Home' for that space).
