Interactivity not Working
Mahulima
Mahulima Contributor
edited February 6 in General
I have the data interactivity available till this point in my workflow where I am doing multiple grouping and then brought them in one place by union
Here is the Workflow screen shot, where till 1 (marked in the SS) I am interactivity . Output of transform step shown above. And now this I am trying to take in interactive snapshot. But when I am taking in a snapshot it is not showing me that option
  • Mahulima
    @Josh Boxer
    I think there is some bug as now the Interactivity should support from union, group. But the ADS is not behaving the desired way when multiple group is clubbed by union? Is that scenario was tested in the release?
    Can you please help if there is any other way to do that with interactivity?
    I think the product is working as expected. "Validate, Group and Profile steps can be linked to an interactive snapshot". If you read the rest of the linked post there is a suggestion of how you might do something similar to a Union that keeps the interactivity.
  • Mahulima
    edited February 6
    @Josh Boxer single group is giving result. But Multiple group and union is not working together which can be product bug or limitation? if the Union and group is supported for taking in interactivity then it should support also when it is combined. I will check the workaround. Thanks Josh
