To be able to use groups and group permissions when using SAML and LDAP
What problem are you facing?
Administrators are currently having to add individual users. This is a pain when a customer has more than 10 users to add.
Not user friendly and time consuming to add users.
Add users one by one.
Support groups when using LDAP/SSO
There is an API to create Users
Also adding 10 users manually takes less than 3 minutes and is a one time job, so I wonder if there is a better reason this functionality would be useful??
As I understand it the simple process of user creation is a bit of red herring here, and the key ask is around being able to use group-based access control from a central identity store to manage Data Studio access.
Supporting groups instead of managing individual user access directly offers several key advantages, especially in enterprise environments:
🔐 1. Centralized Access Control
- Changes to group memberships are made once in the central identity store (eg AD, Okta) and automatically reflected across all integrated applications.
- Aperture already has Groups and Group-based permissions, but group memberships cannot be pulled from the identity store or used to define permissions.
👥 2. Scalability
- Managing access for large numbers of users individually is inefficient.
- With groups, you assign membership once to the group, and all members inherit them—ideal for large teams or growing / changing organizations.
🔄 3. Easier Onboarding and Offboarding
- Onboarding: Add a new employee to the appropriate group in the central identity store, and they instantly get the right access.
- Offboarding: Remove a user from a group, and their access is revoked everywhere—reducing security risks.
🛡️ 4. Improved Security and Compliance
- Group-based access ensures least privilege principles are easier to enforce.
- Auditing and compliance reporting are simpler when access is tied to roles/groups rather than individuals.
