Include Metadata in the Export step
James T Sidebotham
edited January 2025 in Ideas board
What problem are you facing?
I would like to include metadata in the export step (specifically in the JDBC option) that includes metadata for the target system and table (e.g. tablename, DBMS system, credentials used etc.) as this would help users / DBAs to debug/resolve any issues or be included in a point-in-time audit report.
Not easily to tell which system/table the update is for on the export (JDBC) step.
Metadata for the source dataset can be included - but this is a HUGE assumption that the source = target table
Include metadata option for the export JDBC step
3
3 votes
  • See this discussion for more: https://community.experianaperture.io/discussion/comment/3109/#Comment_3109
