Dynamic Reports in workflow - if x then do, if y then do something else
Hi all
I'm new to Aperture and have just built a report in a workflow. It looks good and I am happy with the tables that I have pulled through.
My report shows a summary of all of the checks and then I have an individual table showing the failing rows for each of the rules.
Of course, sometimes, I have a rule that doesn't have any failing rows and in those situations, I would like that section of the report so show a chart which I've modified to just show % of passing rows (it will be 100%).
Is it possible to have conditional routes in a workflow. "If x then do, if y then do something else". I thought split might help, or branch, but I don't know how to tell the report to pick the right option.
Thank you in advance.
I cannot think of a way to do exactly what you want, but Reports (and Dashboards) are interactive, so rather than showing a long list of individual row failures why not just show the Rule (or Rule group) and pass % in the rule or dashboard and let the user drilldown into any rule to see the failing rows if required:
