Annotate Columns
James T Sidebotham
Contributor
in General
Hi, is there a quick/easy way to mass update when performing 'Annotate columns'? I want to add tags not based on the data contents, but on security definitions. E.g. Some columns could be PUBLIC, some could be CONFIDENTIAL. Thanks
Hi James,
Please keep a lookout for the upcoming release (tentatively 2.15.8). There will be an enhancement to the Create and Patch Dataset APIs to allow columns to be annotated with Data tags (only those that already exist in Data Studio). This will allow you to "mass update" the columns with your own data tags.
