Export Data Object to external systems
Sinead Galloway
Sinead Galloway Experian Employee
edited November 2024 in Ideas board
Submitting on behalf of a client:
What problem are you facing?
Cannot export the new data objects to external systems, re-work of re-tagging is time consuming.
Time consuming and need to match the object tags back to the relevant CDE's
Manual updates of data tags in external systems (Purview)
Add the data tags to the data export to be imported to external systems
1 votes
Problem unclear · Last Updated
    Please can you explain further, what is a 'Data Object'? and how have you tried exporting it/importing it into an external system?
