Any Function to check the one field in Present in the List of the fields?
For example I have a column where I have Value like this
If I use function contains then I am getting this true for all of the above scenario, but I want only row 1 should be true and rest should be false when the entire string is not matching. Can this be done?
The value 'XX,YY,ZZ' is a list and there are a load of List Functions that are really powerful and under utilized:
'List-Intersection' is one option
