Prevent object tags from requiring a workflow to be re-published
What problem are you facing?
I have applied the new Object Tags to various workflows. In each case the workflow status changed from Published to Draft when the Object Tag was saved. The tags can be bulk added but the workflows must then all be individually re-published and a comment added.
It's irritating! It feels like a completely unnecessary manual job which is a shame as Aperture is usually good at eliminating boring repetitive tasks.
None.
Ensure that adding Object Tags doesn't change the draft/published status of workflows. Or provide the option to bulk publish - but I would prefer not to have to do this at all.
Interested to hear other opinions here as the object has been changed so it requires republishing.
Coming soon is the ability to Publish objects in bulk through UI, which might remove some of the irritation though would still require a manual task.
I had a similar issue with Object Tags when they were first released, the addition of bulk publishing helped a lot and makes sense for the current draft/publish system.
