swagger UI for find-duplicates- error. after recent upgrade.
We are seeing this error after the latest upgrade.
Upgrade done on our dev is as under.Upgraded to Aperture Data Studio to version 2.15.4 and Find Duplicates Service to version 3.11.3
@Ian Hayden , @Henry Simms , Kindly help and let us know what this is about.
Services are UP, but we usually dont see this error when we try to reach swagger ui with above url.
it comes back fine after every single upgrade. I have also send you email Ian.
Br, HS
  • Ian Hayden
    @HussainSyed I'll take a look and reply via email.
  • @Ian Hayden thanks a bunch.
  • Ian Hayden
    For the record, the swagger endpoint has changed due to a major update of the underlying web services framework. It can now be accessed from this url:
    http://localhost:8080/match/docs/index.html
    Existing API calls should remain unaffected and will continue to work.
