Rows to Columns
I have been testing out the Rows the Column function. However, it seems to be not pulling through all the columns. In the DEV data set, I currently have 62 rows which I would like converted to columns.
When using the Rows the column, it automatically only finds around 56.
Wondering if anyone else has had a similar issue, and if so, how they went about resolving it.
Kind regards,
Will
  • Are the 62 rows unique?
  • Hi James,
    Good idea. There are 2 duplicates which now brings the number down to 60, but there are still some not being pulled through.
    Are there more than 5k rows being reviewed for unique values:
    If so uncheck the box to confirm you are prepared to wait to get all distinct values
  • Hi Josh,
    Yes, there are over a million rows. I have tried unchecking that option, but it doesn't work as expected.
