AWS S3 Dropzone
A Data Studio user had the following question that might be relevant for the community.
Is someone able to elaborate on how an Aperture dropzone on an AWS s3 bucket works?
I have a dataset setup as a dropzone and it correctly picks up new files of a different name when added to the s3. However, if I replace a file with a new version of it in s3, the dropzone doesn't detect the new file. If I delete the file from s3 and reupload a new version of it, the dropzone doesn't detect it.
If i delete the batch in the dataset, and then reupload a new version of the file, it still doesn't detect it.
Does the dropzone literally just look for filenames it hasn't seen before? So if new versions of a file are uploaded, they won't be pulled through? If that's correct, this seems like a bit of a limitation, and feel like it should be using the timestamp metadata on the file in s3 to detect a new file.
